FAM module replacement
palawboy
My left tail light on both the body and trunk, and the LED light on the front left side work sproradically, more often than not. I only found out they were not working when I was pulled over. Our local dealer said it was the FAM module and with labor, will cost me $1100. I found FAM modules online from a Hyundai parts dealer for less than $500. I have seen the diagram of where it goes. Is this something I should be able to install myself?
I have the exact same problem with a 2012! I was pulled over about my rear light out as well. I downloaded the Tail Light diagram. I thought there may be an issue with the Multifucntion switch or the possible FAM module. Can you let me know if replacing the FAM module fixes the issue? I will attach the wiring diagram for the FAM module as well as the Tail lights.
It turned out to be a short in the wires, which a lot of people suspected. The mechanic had to go through a lot of the wiring to find it but I believe he found the short behind the left headlight
