Flasher and turn signals stopped working
hapomykal
2009 Genesis Sedan 4.6 . Flasher and turn signals stopped working. No flasher relay on this car ... apparently coupes have one under dash, but not sedans. Any one had this problem and found solution? Grateful for any guidance.
Did you fine the problem, My hazard lights been on a few days have drained the battery twice. any suggestions
Hello. So from what I read the early Genesis did not have flasher relay (maybe just the 4.6, I can't remember). It sounds crazy but here's what fixed my flasher issue.. There's a fuse box on passenger side of engine bay, up by firewall. There's a cartridge in that fuse box about the size of an old Nintendo cartridge. Please see pictures. I removed that cartridge, blew the area out with compressor, and reinstalled cartridge. I may have removed the battery cables from battery in the trunk before I did this, just to be safe. I can't remember. This fixed my flasher problem. I pray to God it will help you. In Jesus name.
Omg! Your the greatest, Remove the battery and clean the FAM with some QD Electronic cleaner plugged it back in installed battery and instant magic Thanks So Much.
Great.. thank God. I know what it is to deal with things on cars that drive us crazy.. I was praying it would be the fix for you. Thank God
Hello,
I have a 2012 Genesis Sedan that has the hazards blinking continually and draining battery. Should I replace the relay or use compressor?
Hello,
Sorry I don't know. I only can tell you what I did which happened to work. I removed the cartridge (FAM), blew out the area, and replaced cartridge... then no more flasher issues.
Okay I’ll give it a try.
