Flickering lights when using turn signals-DANGEROUS
Raynman10
Cali
This is a problem with the Multi-function switch in 2009-14 Genesis. part numbers 629-50706,
934003M030, 934003M031 make sure you determine if you have rain sensors or not and tilt wheel.
installation is VERY easy. 3 screws on bottom of column case and two screws holding the switch on to column and one connector to switch. it takes 10 minutes.
Parts are found used on eBay or other used parts online stores for about $75 bucks and up. I bought a 2013 #934003M031 for $90 because I thought HMC may have corrected the issue.
Of course there is always the dealer for $500
My headlights went out when I used my right turn signal when the car was about 1 year old. Dealer fixed under warranty. No problems since.
Hi Raynman 10 - you say that this is an easy swap out. Do you need to take the steering wheel off to replace this?
