'skull, I assume that since you haven't replied to the thread you may have already discovered that replacing fog light bulbs isn't too difficult. For those who might be reading and wondering, I just did the driver's side.
My suggestion: Put the car up on a ramp...I happen to have a pair of ramps that allow cars with low front air dams access to the ramp (not as steeply angled). The procedure can be difficult without the access...anyways, once up on the ramp, the front area of the bumper protrudes enough over 'free space' to allow easy access. Under each side is a cover panel, held on by several 'pop in, screw out' fasteners. I removed the three to the front of the car, and on up inside on the sheet metal, engine side. Try a cross tip, and unscrew them...once it comes out about, oh, not quite a quarter inch, then just pull the 'screw head and flange looking thing' out...the spreaders will squeeze in to come out of the hole. If you turn the crosstip and the plastic screw head AND it's flange turn, just pull out with a bit of pressure while turning the plastic screw head to 'secure the flange (and spreaders on the other side). The plastic screw will then back out to allow you to remove it.
Have a flashlight handy cause it's dark up in there. Take a look at the back of the fog lamp assembly. You will have to REMOVE the harness connector first to allow removal of the bulb. if you feel up in there on the connector, there are two tabs, one on each side of the connector. Gently squeeze them and the connector will come free. After that, grasp the connector on the bulb side and rotate the bulb (it will only go one way, counterclockwise to the back of the fog lamp assy). Remove the bulb and replace it with your new bulb. Be careful to NOT TOUCH the bulb with anything...not your fingers, dirt or anything that can cause the bulb to fail after it gets hot. Insert the bulb, rotate it, replace the connector, and the panel. DO the same for the other side. Once you do one, the ohter side will be easy. I esitmate the total time for the job to be .5 hr, and on a difficulty scale of 1 -5, it's about a 2, in reality.
But looking at that procedure from the manual was wonky. I can see if you might want to REMOVE the entire assembly, but the bulbs are easy.
Hope this helps. Another poster here in a thread also posted a couple of close up pics of the plastic retainers....just be careful and you'll be fine.
My left fog light died out and I just bought some led bulbs to replace them. Is there a guide I can use to take out the fogs and replace them? Or has anybody done this before that can help me. I remember seeing a video of someone showing HIDs in the fogs and I didn't like them because they were so bright, which is why I just went with LEDs instead.
