Front Dashboard
sloegenny
Does the front dashboard wiring harness connects to the OBD2 port, the blower motor, and the controls, because I'm thinking of replacing it obd2 port has a cable that doesn't work .
Check your fuses if you are having issues with the blower motor/air & heat controls.
I already checked the fuses. There's a cable running from the blower relay to inside the car, and I'm not sure where it goes. Also, I keep losing communication with my Autel scanner through the OBD2 port.
What is the actual issue you are having? I don't know if the blower motor can be "read" via the OBD2 port? My Blue Point OBD2 reader only does the engine.
My manual shows a notice for the HVAC system: DTC data can be retrieved from the control panel directly or from the DTCusing the "Hi-Scan Pro".
I checked it but it throws no codes from hvac module when the obd2 port feels like working ill be takin it to a auto electric so they diagnose it
