Front door weatherstrip
Packerz1967
New member, here! I have a 2019 G70 and the rubber seal that attaches to the body that seals the drivers door to the cabin has a ripped-out section ( someone (me???)getting in/out car)?.. I can’t seem to locate the correct parts number for this item. Can anyone provide that to me? Has anyone used Hyundaioemparts.com? How difficult is it to remove/replace this….any website instruction write-ups/videos out there? Sorry for long post. Thank you to all replies!!!! Doug
Hey Doug, i used hyundaipartsdeal.com which has all the exploded views and active parts lists. Looks like one of these is what you need. Not sure what options your car came with but you just select them on the top menu.
I've ordered parts from these guys a million times.
I must be dumb, however, I don’t get which part # goes onto body-drivers side door jam on 2019 G70 prestige package (black weatherstrip). Their site doesn’t want to let me identify what I need (part # to order). Do you see it? Can I just reuse the existing #83191 and 82191 clips with new seal/strip?
What am I missing in all this ? Thank you!!!
Nope, you're not dumb. Looks like
82110B
82110-G9000
W/Strip-FR Door Body Side LH
Is what you need, for Front, Left Hand Door, on the Body Side. I am not sure if you can re-use the clips but I don't see why not. I'm not sure if they are removable, but if you can remove them and put them on the new strip, I see no reason why you couldn't reuse them. The clips aren't supposed to wear out anyways.
The door has TWO full rubber seals: one attached to the door, and the other to the body. Since you need the body one, it's going to be 2nd one on the diagram on post #2. They have 2 P/Ns for some reason, but post #4 above seems to have the full number you need. As far as the clips, they're removable and they can be reused, but I don't think the body seal needs any (the door one for sure). If it has any, just relocate them. Good luck.
Thank you both!!! I just wasn’t following the diagram for the correct part number. Greatly appreciate your help thatjawncrazy. Take care!
