Front radar grill discoloration
Mantronics
Is there a way to touch up or repair the front radar vs replacement. Warranty is up and I’m sure after market warranty won’t cover it. 2015 3.8. 🙏🏼
Same as refinishing headlights, maybe ?
Looks like crap. Was it clear coated at some point? Sort of looks like what happens when clear coat on a car has aged and starts to fail. I have a G70 and have never looked close enough if the plastic is coated or if I could even tell.
Not sure, second owner. Yes, it does look like crap.
I just had mine cleaned and recalibrated by the dealer under warranty. I was told to be cautious about cleaning yourself, but if you do you should have the dealer check it. I would have the dealer do it even if not under warranty. I was told replacing the unit is more than $5000.00 if not under warranty. Looks like new after cleaning. Operation normal before and after.
I'm having the same issue. I was maybe thinking it was a protective film....might have to take it to someone who does ppf to confirm if so I might take a eraser wheel to it.
Same issue here but mine looks like frost on a windshield - I think it's the protective film that the dealer was supposed to remove upon delivery. It's very difficult to remove. Won't scrape off, bug and tar remover doesn't work, Goo-Gone doesn't work.
