G80 Ultimate Blower fan direction
Dennis Larkin
When I set my blower to only blow on my feet it still blows on the windshield quite a lot. I can never get 100% of the fan on the feet. Doesn't matter what mode I'm in. Is this a defect or does this happen on all of them?
This has been the case on every car I have ever owned that had vacuum dashpot or motorized air control. Every owner's manual on every car I have ever owned has indicated this in the section dealing with the cabin HVAC. I assume it is to keep your feet warm and the windshield clear in cold weather. With the old-time slider control that actually pulled a cable, you could tweak it as desired.
Only a small amount of air should be on the windshield when you have selected the floor position. You can take it to the dealer if you think something is wrong or try another car on the lot to see if it's different.
When I have it set to the floor the amount of air coming from the top is probably 60% or more. I'll mention it when it goes for the first service.
