Gas cap door tip
Alwaysforward
South Florida - Treasure Coast
While getting fuel a few days ago I pressed the door release button and nothing happened. After the third try it finally popped open. When I got home I opened the door and sprayed the plunger down with WD40 then wiped up the excess. I repeatedly pressed the fuel door button and it worked every time with ease. Just thought I would pass this along.
On a side note there is a quick release pull cord located in the trunk in case you can't get the fuel door opened.
Nice work! Thank for the tip. It's actually cold in the NE and we have ice, so I'm hoping the gas door behaves!
On a side note there is a quick release pull cord located in the truck in case you can't get the fuel door opened.
Thanks, I did not know.
Wait....there's a truck in the trunk?
Corrected Typo... 😊
