Genesis 2013 dashboard DEAD and won't start...until you close the TRUNK!
OldT
This has happened 3 times consistently over the past 3 days: You go to crank it but the dashboard display and all electrical components are DEAD and car will not start. Then if you manually open and close the TRUNK, it starts. Ran fine for 200 miles after it started (didn't stop during trip). Any thoughts?
Loose battery cable clamp?
Given the battery is in the trunk it is probably shaking something. Have you checked the cables and connections?
Thanks but battery cables are fine (first thing I checked). I don’t slam the trunk, just open and close it. When I do that, I hear a distinct click - like a reset or something registering - and then power appears on the dashboard and car can crank. One thing: after power reappears, car cranks kind of hesitantly.
Believe me or not it has something to do with your battery connectors This happened to me before on several occasions It took me a while to figure out but I did Especially that postive terminal It may appear to be well connected but still came lose after going over a few bumps while driving which obviously happens when the trunk is closed So what did I do?? I was so upset that I hammered a wide short nail between battery post and connector and a little bit into the battery I been good for a long time now
You were ALL correct, it was the positive battery cable... I looked at it but it seemed ok, but a friend checked it out and said I'd missed the loose contact. Seems to be operating correctly now. Thanks for everyone's input!
