Genesis 2015 camera stopped working
dfrazier
The rear view camera in my G V3.8 stopped working. When I put the car in reverse the camera doesn't turn on. The radio and all other functions associated with the touch screen are still active when the car is in reverse. Shortly after this occurred, my tail lights started blinking while I was driving. This has been resolved by adjusting the negative battery cable. Is there a fuse associated with the camera? If so where is it located I've checked the fuse box in the hood but found nothing that indicated a fuse associated with the camera. The dealership is charging a 150 to run a diagnostic test, I would like to know if others have had a problem with a Genesis 2015 3.8 camera and if so how was it resolved.
Thanks
Dave
One known issue with the backup camera is a fraying wire harness. It frays in the trunk. That might be it. But they must be careful not to have the battery connected. While fixing my backup camera they fried my head unit.
Thanks for responding, where is the trunk is the wire harness, or how do I access the wire harness?
Don't remember exactly. The location is shown in one of the other threads here.
the wiring harness in attached to the underside of the trunk lid and follows hinges, i believe on the right side. My harnes snapped almost completely in half, i had it replaced under warranty at the dealer. The motion of the trunk opening and closing over time breaks the wires in the harness. It happens to alot of cars. Its similar to bending a metal hanger back and forth until it snaps.
Yup, happened to me early this year. I had the blue screen with yellow grid lines. They repaired some wires and it’s been working ever since.
