GV70 2023 Android Auto USB and USB Music
hersche1
Genesis GV70
This is my first post. New GV70 owner. Great car with limited USB options.
Background:
Using Android Auto with the USB SS (SuperSpeed) port with Samsung S21 and official Samsung cable.
Unfortunately, the car only has one USB SS port (surprising I think)
Question:
I would like the option to use Andriod Auto along with a USB memory stick with music on it (large CD collection). I tried to use a USB hub that will not work (I don't know if the hub is USB SS compatible, its new so I am assuming it is)
Does anyone know a workaround or suggestion to allow more than one device to work properly with one USB SS port?
Thank you
additional comment: this car 2023 model should have Android Auto and Apple Play using Bluetooth and have USB SS as an option and not a requirement. I have a AAWireles dongle, doesn't work so great.
I am having the same problem i try a few adapter from Amazon and nothing seems to work.
Sorry I am unable to provide any suggestions or solutions, but I am curious with your situation. Is there a reason you'd rather use a USB stick with music loaded on it instead of the music being stored and played from your phone that is connected to the USB SS port?
I have been trying to do this as well. I have a wireless adapter plugged into the USB port and I don't want to just play the music on my phone - and not sure if the quality is as good as a drive plugged directly into the port, so wanted to compare the two. If I unplug the wireless adapter and plug in a stick, then I have to reconfigure the wireless adapter, etc...just not worth it. A hub would be great but if you look at the ones on Amazon, they usually specifically say they do not support charging or AA/CarPlay.
