Head lights wont work & Right turn signal
stan585
I took of my front apart on the car to change my radiator core support after one side cracked off it. After putting everything back together, my headlights wont work only the orange ones toward the center work. Also my right turn signal is glowing always on my dashboard when i turn on the head lights, when I try to turn on the turn signal to the right it wont work but left works fine. Any ideas on what could be causing my problem?
Update on problem- Left signal works fine and blinks fast on dashboard
Right signal on other hand blinks slow when no head lights on but when you turn on regular headlights it blinks fast as it is supposed to. After you turn on high beams it stops blinking all together and just glows but the left side is fine. Anyone ever have this issue if so what did you do to fix it?
I would guess you have pinched or shorted some wires together in the assembly. I would carefully trace the wires to make sure everything is where it is supposed to be before you cause something more costly to blow/break
Are you sure the car did not run over something or hit something that caused hidden damage?
I'm having a similar issue... Was cleaning my filter/intake/TB and i accidentally knocked a socket down in the engine bay. Fished for while with my magnetic snake but couldn't find it. Had to pull the under gaurd off to get it. (I have no idea if fishing around could have caused this or if it is something that was already present--recently gave the coupe to my wife, and I know she probably hasn't noticed a thing... women)...
I locked my car and i noticed the driver side mirror led was not signaling but the passenger side was. I then noticed the left side parking light in the front is out. All other lights work on the back, front, etc. THEN i noticed on the left side of the car the proximity button on the door is not activating (I've experienced this before when the key was dead, but never when it has fresh batteries. I tested the passenger side and it worked fine... Did i blow a fuse or something? Too much of a coincidence this is all happening on the left side of the car and at one time.
