Headlight rubber seal came loose
LESwilliams
Anyone had this problem. Mine now just flaps in the wind and I don't know how to reattach it.
YEP! LOL....I got the same problem on my 2012 3.8. I'd posted that we've have moisture intrusion into the right headlight assembly (I don't have the thread) but bout that time the rubber cover gasket things decided to loosen up. THey are still attached at the rear so I have to push them back towards the engine...otherwise, if they come out, you think you've hit a bird and it's flapping around stuck in the grill. If you pull it up and look, it appears there was some sort of thick double-sided adhesive used, and it may be possible to clean the rubber as well as the top of each headlight...the channel where the rubber fits down into, and reattach it. I'm looking for a part number either for the adhesive (you may notice that if you try to glue it, it may not fit too well) or the flaps....
But to keep them from flapping, and you will eventually lost them if the rubber tears, just push them back towards the engine and let the hood hold them in place.
PM me and I'll give you my phone number.
