Welcome. This topic has been moved out of the community lounge and into the first generation Genesis Sedan forum...My 2012 genesis hazard lights came on just parked. How do I get them off.
I had the same problem, Here's what I did disconnect the battery. Buy a can of CRC Electronic Cleaner unplug thr FAM and spray clean let dry. I noticed by pulling the fuse on the driver side dash in and out it caused a clicking sound under hood on the passenger side so I traced it to this relay was clicking and replace it. Hope this helpsMy 2012 genesis hazard lights came on just parked. How do I get them off.
Did you find an answer. I’m having the same issue.My 2012 genesis hazard lights came on just parked. How do I get them off.
I’m having same issue. I have a 12 Genesis Sedan. Did you find a solution to the hazards staying on?My 2012 genesis hazard lights came on just parked. How do I get them off.
I have read where replacing the FAM on your case cleaning the fam may have only worked temporarily. Is your fix still working? Thank you for your time!I had the same problem, Here's what I did disconnect the battery. Buy a can of CRC Electronic Cleaner unplug thr FAM and spray clean let dry. I noticed by pulling the fuse on the driver side dash in and out it caused a clicking sound under hood on the passenger side so I traced it to this relay was clicking and replace it. Hope this helps
