help with glove box bulb change
imitiday
western pa.
How do you get the lense down to expose the bulb?Can you remove the whole assembly or do you have to change the bulb in place?
Many thanks,JNP
Many thanks,JNP
You can remove the whole assembly. You will need to press on the connector release tab on the black connector.
thanks fiat,but how do you remove it? I see no screws holding the lense in place like you have in trunk & license plate.There is just a small tab on left side of the lense that moves slighly inward,but that's it.Do you have to try and pry it out with something? I seem to be stuck! Tks JNP
Just hold the tab and pull down. Use a small flat head screwdriver it will come right out.
