High Beam bulbs
jake the snake
Montreal, Canada
Yo Guy's
Does anybody know the part# of the high beam bulb???
Has anybody tried to swap them for aftermarket xenon???
Would like to have them cool white instead of Yellow
Thank's
CIAO
Your high beams (according to the manual) are 55 watts.
I'd imagine there is a aftermarket kit that will fit in the slot for the high beams (e.g. the plastic insert in the casings... not the "electrical slot")... but there's always the risk of electrical short converting to aftermarket xenon... unless you REALLY know what you're doing.. be careful :) that's my caveat for the day
Make sure you have an inline fuse to the battery to prevent a short from messing up your wiring.
May I ask why you aren't happy with the halogen high beam?
I too, found distaste, in the lack of a bixenon setup,, but don't use high beams often enough to worry about it.
Hi ENJOYINGSILENCE
I use the high beams every night comming back from the gym.
I do twisting roads in the country.
The low beams are a nice bright white color.
The high are a yellow even though they are quite bright.
I find that the yellow covers up the white.
I would like to istall some Xenon super white on the high beams ( not HID )
Just trying to find the part # of the bulb taht we have.
If anyone knows???
Thank you
Bulb type ( Sylvania SilverStar High Performance Halogen High Beam Bulb )
9005 ???
Let me know
Hi ENJOYINGSILENCE
If anyone knows???
Thank you
I'm sure one of the members here has access to the parts database @ hyundai and can reference the part number for you.
Also, I suggest you reference color spectrums, and research how the overlay occurs from HID to halogen bulbs... just to make sure you get the desired effect :)
Has anyone tried to change them yet???
Does anyone know how to remove the HIGH beam bulb???
Please let me know
CIAO
Thank you very much BaywayRic
After reading the how to on the lights, I have decided to get the dealer to do it
Very glad I did not try
Again Thank you
CIAO
The high beam bulb size is H7.
To get to them you have to remove the front shroud that sits under the front edge of the hood and wiggle your way in to remove round weatherproof caps that cover where the bulbs are. There isn't a lot of room in there and I had to move the fuse box on the left side to get to it. I didn't feel like removing the air box on the right side to get to it but it looks like you don't have a choice to take it out to have access to the high beam bulbs.
