I just spent about an hour going through all the posts here.
I think I understand the issue where the EQ falls back to default(all 0s) after a power cycle.
And that some owners are not too satisfied with their bass output.
I didn't see any confirmation that this EQ reset issue is an isolated problem for the 14-speaker Lexicon system.
Did anyone w/ the top end Lexicon system encounter this same issue?
Is it safe to assume that this issue only applies to the 14-speaker systems?
I have the 17-speaker system, and honestly I didn't notice any problem with the EQ setting.
I used to like bass-heavy musics in the past, but definitely grown to appreciate accurate sound reproduction.
IMO, the bass reproduction in the Genesis Lexicon system(tech pack) is superb.
Although I sometimes miss the pounding bass of the
aftermarket systems I had in my older cars, I have to say I'm 99% satisfied with the stock Genesis system.
I have to admit that I have the bass set at +8 for the CD/MP3/AUX and +6 for DVD-A.
When I listen to musics at nominal level(11~20), the bass is tight and deep.
Only thing is, when I turn the volume higher(20+), I can feel the lack of bass compared to highs/mids.
It would be great if I could add a 10" or 12" sub with a decent amp replacing the stock 8", but I'm afraid that it'll screw up the balance of the whole system.
Plus, I'm not even sure if just adding a sub will be a remedy for the lack of bass.
It could be 100hz~300hz range that's lacking, which a sub wouldn't fix.
It was a great read, this thread. Will spend more time listening to the system and check back later for updates.
Thanks, all.
Dan
