How Do I Change the Default Audio From "Audio Off" to Bluetooth
SahilG
How do I make bluetooth the default audio so that when I get in my car I don't have to change it every time from off to bluetooth?
Also how do I change it from "Audio Off" to any other audio option upon startup?
All I had to do was pair my phone with the car, and if I was listening to spotify before I shut off the car, it defaults to bluetooth audio when I start up and all I have to do is open spotify on my phone and hit play.
In my experience, the radio remembers the last setting I used before turning the car off, so if I was listening to spotify, it will start up in bluetooth audio mode; if I was listening to sirius, it will start there, and if I turn the radio off, it will start with the radio turned off.
Hope this helps.
Hope this helps.
Mine doesn't do that. Maybe there's a setting i accidentally turned on. As soon as the car turns back on, it says "audio off".
That's odd - I can't seem to find any setting that would cause this behavior - have you tried resetting it?
Go to your general settings under media, there is an option there.
Ive got mine unchecked, and since the update it always defaults to off when I turn the car back on. Tried checking and unchecking, no changes. Not the biggest deal, but a minor annoyance
Did you do the 2nd update? I think the initial update had some issues. I just tested mine checked and unchecked and it works as it's supposed to.
I ordered the SD card, not sure which one that is.
Tested more. It works fine if I have the radio playing when I turn the car off. But when using CarPlay I unplug my phone and now it doesn’t turn back on to the last used input (fm radio) it just goes to media off
