How to get access to pedal assembly?
I assume you are referring to the "accelerator pedal", which is the only pedal I know of in the car's interior.
This pedal is bolted to the floor with a 10mm bolt at the bottom of the pedal. It is covered by a small plastic cover. The pedal is otherwise held to the floor by a slide-like assembly near the top of the pedal. Merely slide the pedal assembly downward and the entire pedal assembly will release.
