How to remove door handles?
Bhavie
Ontario
As the title implies. Planning on doing a chrome delete so would like to remove the handles to make it easier. Based on inspection there's a small screw on the inside of the handle when you open it, but I'm not sure if that's enough to remove the whole thing.
There's a thread on here of someone whose removed the handles for the same reason, but he's unresponsive. So I'm hoping someone else in the community has some insight.
If it is like most vehicles you will have to remove the door panels and there are 3-4 bolts on the inside of the doors that remove it, you will also have to remove the wiring connectors for the button lock function and the lock pin rods that lead to the latching and locking mechanism.
you can search YouTube, 99% of all vehicle door handles are attached the same way.
Here is a video for a 2013 Hyundai elantra, It is likely 99% the same as the g70
