CenTexan
Wow - getting kinda complex . . .
I do believe I have narrowed down my USB problem to the presence of the USB stick itself. Seems that whenever the (energized) system senses it, the AV turns on.
I tried several variables, and it seems that as long as the stick is in place, the AV turns itself on whether you want it or not.
FYI, I tried:
1. Car and AV running, turned to XM, turned off AV, unplugged USB stick, then stopped car; result: AV stayed off at startup (no USB stick in slot).
2. Unplugged USB before starting car, then started car - AV stayed off (was off before shutdown). Then inserted stick: AV autostarted. (BTW, it defaults to the root audio file present on the stick, in this scenario.)
3. Engine running whole time, USB plugged in, then turned off AV (had to manually turn it off, of course!) - then, engine still running, unplugged the USB and reinserted it - and, bingo, the AV turns itself on. Again, root audio file played)
4. While engine is running, turn off AV, turn off car. Then unplug USB, wait a few seconds, then reinsert USB. Wait a few hours. Upon returning later in day, when starting the car, the AV autostarts (and plays the audio file that was being used when I originally turned off the AV, regardless of file location on the stick. So apparently there is some type of "memory" set on the stick or in the AV system).
I think I will discuss this with the dealer service department. It's really annoying to have to manipulate the stick to keep AV from coming on.
FYI, I tried:
