Hud
Makan Del
Hello
Is there any way that I can add heads up display to my 2015 genesis 3.8? It has technology package but unfortunately not the ultimate package.
Thank you in advance
Hello
Apparently the HUD needs a special windscreen that people have reported costs north of $2,200 to replace (http://genesisowners.com/hyundai-genesis-forum/showthread.php?20094-Cracked-Windsheild-in-Ultimate). Then you need the HUD projection unit, which is mounted on top of the instrument cluster, I assume that's probably not cheap as well. Wiring harness, installation, etc. will probably add some more $$$.
I doubt this will be done for under $3,500, probably more. Plus you won't have a warranty - I would personally not touch this project on my own car. I have an Ultimate, and the HUD is awesome (my favorite feature on the car), but I would not spend that kind of money to add one.
I would look at trading yours in on an ultimate. You'll maybe lose some on your car and obviously have to pay more for the ultimate but I'd rather go through the extra money and have a factory-installed setup with a warranty.
Totally new dashboard. Non-Ultimate models do not have the opening for the HUD. There would also be the question of where to obtain the signals and how to get the option onto the menus so that the HUD could be controlled.
Not a possibility at almost any cost in my humble opinion.
There IS a solution but it's not OEM. It's not expensive... Click here and check out this option. There are others as well...
