doomstrike
- Aug 25, 2023
- Genesis Model Year
- 2010
- 1G Genesis Coupe (2009-2016)
HI folks,
My beloved Genesis (1st owner) is no longer starting for me due to 0 psi compression pressure in all 4 cylinders at 105,000km. Initially i got camshaft and crankshaft sensor fault codes P0016 and P0340). Replaced both sensors.
I noticed the oil is metallic and the camshaft sensor was covered in metal (the sensor itself is plastic but the magnet inside glued to metal dust to it).
I can see the timing chain is not where it should be, i suspect the chain jumped or the gears jumped.
I am trying to find the exact engine type/model specs; a vin decoder shows it as EngineCapacity: 2000 CC - THETA FR EngineType: DOHC - TCI/MPI.
The wiki on the Genesis coupe start at 2011+ on the Theta II engine., Hyundai Theta engine - Wikipedia. What's alarming about this wiki, even thought 2010 is not listed, is that it showed over half a million engines recalled due to metallic oil and a class action lawsuit. Am i seeing the same problem on my 2010 2.0T (Turbo RS cover) model Theta FR engine?
Would appreciate helping me find the timing specs for this engine and more details on the engine to lookup.
