Hyundai TSB 21-50-003 Issued 23 July 2021 concerning 8 Speed automatics 2012-2015 Gens/Equus/Coupes
After swap to new brake booster, transmission shocks disappeared
Why would that cause transmission shocks
Here you will find the response :)
Ah didn't see that thanks buddy!
Thanks @Roc! Finally purchased my first Genesis (6th Hyundai) a 2015, 3.8 with 141K. It has the Harsh or Delayed Shifting issue. Scheduling my appointment at Laird Noller Hyundai today. Will update thread after service. Appreciate all those who have come before me!
Nowe, to learn about the power trunk lift gate that unlocks and immediately shuts. It doesn't fully open.
Any Luck?
Hello guys, new update with the problem of transmission.
Accidentally we found that on Genesis DH, there is a problem with Brake booster, the central membrane is broken in wet (medium) climate (i thinks its a time problem of anywhere).
The main idea that brake booster gain much more air than needed, and the valve isnt closed when needed, as a result, the ECM gain wrong data from the Torque sensor, and thats why we got transmission shocks.
In attachment you will see photos from two different genesis, with ODO km 70k km
Hello, and thanks for this important insight! Can this problem be identified by external inspection only, or must the brake booster be disassembled? Below is a picture of this brake booster for sale on Ebay, does this picture look like no rust problem?
How is your transmission saga going? I recently purchased a 2015 5.0 Genesis, love the car, but am seeing flaring and slightly harsh shifting, I am at 94k. I am going to replace solenoids and pan in a few weeks.
Hello,
unfortunately no.
But those cases with brake booster, was the problem only from two of 20 cars.
Anyone solved the problem?
I have same problem delayed shifting
And noticed there is delay respone in throttle
I am having this issue in 2-3, 3-4 and also noticing a hard shift down from 3-4 at times. Its not constant and cannot tell whats causing it per say as during the cold its hardly noticeable but on warmer days i can feel it for sure......
I had no issues and had drain and fill done last year so not sure if that created this issue.......
I also had a brake line issue and the local mechanic who fixed it also either damaged the ebrake module or at least the ebrakes as they broke......he is no longer in business lol........not sure if that is related to the tranny issues noted in this thread and at this point i am scared for the options on my 106,000 miles car :(.
I had another user give me the TSB noted but its not a reacall so not sure what options I have (buy my own solenoid and a transmission shop to fix?). The car value is 5-6k? Drive it until its dead....?
Shahhere
