Eddie Horn
- Feb 21, 2017
So I have a 2009 Genesis sedan with the 3.8liter engine with only 40,000 miles on it and the other morning I started it up on a cold morning and heard a lot of valve clatter sounds that I have never heard before. I immediately shut the car off and proceeded to check my oil since I had just got an oil change maybe 2 weeks ago. My oil level was fine not a drop gone.When I put the oil cap back on I noticed it says 5w-20 on it and immediately checked the oil on my paper work and it said 10-30 on it. So I called the company that did the oil change to ask them what was the recommended oil and they said computer showed 10-30 .....So afterwards I called up Hyundai and asked them what was the manufacturers recommendation and they said 5w-20.So I asked what would happen if they used 10-30 in it and they said it would wear out my variable valve timing and cause it to go bad.They said 10w-30 isn't recommended at all and not to put it in. It must be 5-20.
What are your thoughts and has this happened to you?
Who should I contact.
Do you have any references about the vvt and what oil must go in.
