Input on Back up camera and power seat back motion issues Bart and My Genesis 2009
BartGenesis
Looking for input on resolving issues with my 2009 Genesis sedan.
  1. The back up camera
  2. Driver power seat back motion
  3. Driver Handle lock button
The back up camera does not show any image. It shows the guide lines but the rest is all black. Once I saw cloudy white for a few seconds. For my 2009 sedan which is the "fuse" label that includes the camera. I want to try the reset solution.
Welcome. Moving this to our first generation Genesis Sedan section.
The cameras are prone to corrosion unfortunately. All you can do is either splice in a different camera to the existing wiring, install a secondary camera system (my car came with one) or replace the OEM camera with a new one.
Thanks for input. I suspected that is the problem.
Got a used back up camera from eBay and works great
I covered it in plasti dip to keep the moisture out of it
On a side note go to the dealer and get the rear panel clips if your gonna replace the camera
Cause you will break some
Is there a part number for the rear panel clips I need to replace some
The blue ones are on the bottom corners and most likely break cause you can’t get to them
The yellow are in the middle
I got two of each 41518752-8C40-42D0-B9AD-7B3D25440EB2.webpAF947A3F-2527-482D-9473-6A07347C64B4.webp
Oh and most likely the screws that hold camera
Will be rusty and corroded and won’t come out
I had to cut mine off and use a bigger screw to secure it …you ll figure it out once you see it .
