bjohns5
I picked up a Genesis steering wheel emblem on ebay that is different than most I have seem. I like the embossed look rather than the clear dome appearance that most designs have. This one is intended for the coupe so it isn't a perfect fit, and it will not go over the existing logo so you have to remove the H which is a PIA. I stuck some 220 grit sandpaper to a scrap of plywood and sanded down the back until the whole thing was about half the original thickness. The emblem is thin metal so it takes a while to sand down but the result is that it doesn't stand as proud above the surface. I am considering taking it back off and using a Dremel tool to carefully sand down the plastic on the steering wheel where the original H mounted so the new logo will be more recessed.
If you'd like one yourself, the eBay seller is the3rdcanonshooter and his store name is doubleclutch77
