Instrument panel Lights
SouthofGeorgia
I'm a new Genesis owner. Love it! But, I find that unlike all
> other cars I have ever owned, I am unable to dim the instrument
> panel lighting to an acceptable level at night. In my previous
> cars, I could actually shut off the instrument panel lighting
> with the scroll adjustments. With my Genesis, I can dim it slightly
> but it still remains brightly lit. Is this normal or do I have a
> defect
Doesn't shut off but dims enuogh for me.
They probably did this way because rest of the buttons and switches.
4.6/tech
> defect
Totally normal. Many older instrument lighting was incandescent and it can dim from 100% to zero. Not sure what the Genny is using but from the looks, it appears to not be incan. So, that may have a bearing on why the small percentage of dimming.
The Genesis has two level of brightness control for the instrument panel and it is linked to the light switch. If the light switch is at the "off" position, there is a very small range of control. Once you turn to the parking or headlight position, you can varies the brightness from full on to almost totally dark.
By "off" do you mean automatic?
