iOS 13.0...no bluetooth connection
glennk
Dallas, TX
Upgraded to iOS13.0 and now my Genesis will not connect via Bluetooth.
Each and every app now has Bluetooth permissions.
is there a fix? I don’t see a way to give Genesis permission for bluetooth
I upgraded to 13.1, but still not resolved. I just shut off my bluetooth, as I cannot stand hearing the nav system complain about no connection.
remove the Genesis from Bluetooth on the phone
remove the phone from the Genesis in the BT setup.
re-attach the phone to the car as a new device.
approve the BT permissions prompt on the phone after the connection.
Will do.
Mr. Incredible....I have paired my iPhone to a 2017 G80 and know those instructions and how to remove Genesis from the phone. I don't know the instructions to delete it from the Bluetooth setup. How do you do that?
Thanks.
PS...sounds like another reason to hold off on iOS 13.
Thanks.
Unless this is incorrect....just found this on page 3-5 in the Multimedia Manual. Mr. Incredible, is this what you did to delete the phone from Bluetooth?
Thanks.
13.1 works fine on my G90. Didn’t ask any permission questions (although it did for other devices).
yes
FWIW I have had to do this in all my cars with 13 and had to do it with I went from 11 -> 12 as well. Also had issue with my Air pods, Apple Watch, Bluetooth Speakers and even my Savi 745 headset I use for work (it's an all in one headset that connects the desk phone, computer soft phone, and cell phone to one heatset)
anytime Apple makes changes to the BT programming it breaks existing connections. I suspect it's probably the same with Android..
yes
iOS 12 or no previous update broke my BT connection in the Genesis G80. I have an iPhone, but I'm still holding off on iOS 13 for other reasons. It's reviews have not been good.
No problems connecting with iOS 13 in either my 2012 or 2015.
iOS 13.1.2 includes bug fixes and improvements for your iPhone. This update:
- Fixes a bug where the progress bar for iCloud Backup could continue to show after a successful backup
- Fixes an issue where Camera may not work
- Addresses an issue where the flashlight may not activate
- Fixes a bug that could result in a loss of display calibration data
- Fixes an issue where shortcuts could not be run from HomePod
- Addresses an issue where Bluetooth may disconnect on certain vehicles
Do you have to update in succession? I have original software in my 15 ultimate can I go right to latest update or do I need to go in steps.
Just go to the latest, no interim needed.
