iPhone Navigation Integration thoughts
morsegeek
Minneapolis, MN
My Genesis is a 3.8 Premium Plus without the tech package and thus does not have integrated navigation. This was a deliberate decision on my part since I plan to keep the Genesis for a long time and do not want to be locked into an outdated navigation system that is useless in a few years.
As an iPhone owner I have made do with the built in Google Maps application and it has served me fairly well but, at long last, the iPhone has received true turn-by-turn GPS navigation!
There are several turn-by-turn navigation applications out for the iPhone now, with two of the best being from TomTom and Navigon. They work quite well and I would like to use them in my Genesis, but the major problem I ran into with this is that the Hyundai iPod/iPhone cable is abysmally short and does not allow putting the iPhone in a convenient viewing location for use as a GPS navigator.
I've thought a little about solving this problem and think I've come up with a solution that will work but I'm also wondering if any one else has run into this issue and come up with a different solution already.
My first thought was that I could use an iPhone dock cable such as the one that comes with all iPhones instead of the Hyundai cable. Unfortunately, due to Hyundai's omission of an Apple authentication chip, the proprietary Hyundai cable is absolutely necessary. I also don't think that extending the cable on the end that connects to the car is feasible since, while the USB connector is standard, the headphone jack connector is not: it has four connections like the iPod earphones instead of the usual three (left, right, ground).
This leaves one option: extending the cable on the end with the dock connector that plugs into the iPhone. Dock connector extension cables are surprisingly hard to find, but I did find one for sale at this site:
http://www.cablejive.com/dock-extender-cable
Assuming that cable solves the problem of getting the iPhone into a place where it is conveniently visible for navigation, I now need a good way to mount it. I know there are windshield mounts available for the iPhone but I live in Minnesota where this is illegal, so I found a nice (albeit pricey) alternative in the Proclip. This customized (both for the vehicle and device) mount attaches to the A bar and places the iPhone in an optimal viewing location. These are available at Proclip:
http://www.proclipusa.com/
So, my solution is a combination of dock extension cable and iPhone holder. This allows me to navigate while listening to music on the iPhone over the Lexicon system and has the added bonus of putting the iPhone screen in a conveniently viewable location so I can see who is calling (the Premium Plus bluetooth system does not announce this, just "incoming call") and use other iPhone functionality that requires a view of the screen.
The solution is not cheap though. The total cost:
6' Dock extender cable, shipped..................$38
Proclip Adjustable Holder with Tilt Swivel.....$40
Proclip Left Mount.........................................$30
With shipping costs, total: ~$117
I have not made this purchase yet so I can not be sure that everything would work seamlessly but I am fairly confident that it would. Have other people come up with different solutions to this problem? Is it worth the cost vs. just getting a standalone navigation system?
I think the answer to the second question is probably no, but there are other benefits to having the iPhone so conveniently placed in the Genesis besides navigation. It would allow better control of Apps like Pandora that I use in the Genesis. I would be able to see which song was being played, for instance. I could watch videos while charging the phone when in park. I could also make calls from the phone without having to enter all my contacts in to the Genesis' address book. I could make the call from the iPhone and when the call was connected it would automatically use the bluetooth for audio. There are probably other uses for this placement of the iPhone that I haven't thought of as well.
Thoughts? Other solutions?
Great find! I think it will really work! Have you double checked to make sure that the 6' cable is enough length to route it from the center console to the left mount? Let us know how it works out.
I'm also curious how this turns out.
I noticed that CableJive will make a custom length extension cable (up to 14 feet), so a fairly clean solution should be possible.
Any updates?
I recently got an iPhone, so this is a fairly appealing solution. But the other ProClip mounting area on the right is probably dangerous (as you'd have to look down at the gear shift area to see the phone). However, I'm also concerned about the cable routing appearance and whether the positioning on the left column will interfere with the side curtain airbag deployment.
I don't have the Genesis yet, so please take my comments with a grain of salt.
I have the iPhone and the Navigon navigation app. Works well.
With regards to the mount, the ProClips work well. I've used them in two cars so far for the iPhone.
With regards to integration with the stereo, I currently use the dLO Transdock Micro FM transmitter. Its the best one I've found so far out of the FM transmitters I've tried.
Its too bad you didn't get the tech package. I think the tech package supports Bluetooth A2DP. If it does, that would have been the preferred way to go. All you would need then is the iPhone cable to charge the iPhone and let the iPhone use Bluetooth A2DP to stream audio to the stereo.
Unfortunately, the Tech Package (at least the 2009 model) doesn't support A2DP, just the headset profile for voice calls. However, when docked via the Hyundai iPod cable, you can output the iPhone's audio (including services like Pandora) over the factory stereo.
I've been extremely busy of late, making the most of the fast-waning Minnesota summer, so I haven't had time to go through with this yet. When I do, I'll post back to this forum with pictures.
In the mean time, if anyone else tries this or has come up with a different solution for putting the iPhone in a more visually accessible location, it would be great to see pictures.
Has anyone else mounted their iPhone in the Genesis?
