Jukebox question.
joeyz400
Is there a way to set up favorites or folders in the jukebox? I tried downloading 2 folders from the same thumb drive. I only see 1 music folder and I can see the pictures I downloaded from the same drive as well.
Favorites, no; folders, yes.
When you insert the USB drive, hit "List", then select "Albums". Then copy to Jukebox. That way, the entire USB drive will be copied instead of only the album that initially came up playing.
It took me a while to catch on to this since it is not published anywhere that I can find, but I regularly put a number of folders on a USB drive and copy them all to the Jukebox in one operation. I have about 1500 songs on the Jukebox at the moment.
Thanks. How can I add another folder?
Can you get Album cover art on the Jukebox? If so, how do you do that?
Thanks worked perfectly. I'm not sure if it is in settings.... I have the cover art and it says gracenote.
Ok, Im new with my Genesis, & LOVE IT thus far. I have my USB with 3 folders which show up when USB is plugged into car... I may have mis undertstood above, but i thought you can SAVE music to the car??? or is this a cetain feature, It seems i cant save music to the car? Or do I just plug USB in to play my Favorite music??
See page 54 of the DIS Navigation System / Owner's Manual. It explains how to copy the files into Jukebox (the cars hard drive).
When the USB drive is plugged in go to the of the screen and select list and all your folders will show up. Check the folder you want to copy your Jukebox and select add. Wait till everything finishes and then the music/pictures or videos you have copies will show up in media Jukebox. No need to keep the USB drive plugged in.
The car has gracenote and will update any missing cover art.
