Just purchased a 2011 4.6l with 100k miles! What are some of the first things I should do/check?
mch4424
To be honest, I have never even heard of the Genesis until a week ago when I saw a Hyundai on Craigslist, but after driving it I knew I had to have it. I am wondering what things I can do straight off the bat to improve quality of the vehicle overall.
Things that have just been completed:
  • Brand new tires
  • Brand new brakes and turned rotors all around
  • New oil change with Mobil 1 synthetic and air filter/cabin air filter
  • New differential fluid (Mobil 1 synthetic)
Here are some questions I have about the vehicle in general after reading through a bunch of forums.
  • Is there truly no way to use bluetooth or USB input with a Galaxy s20 phone? Seems bluetooth is only for phone calls and the USB is just for mass storage. I use Spotify and simply want to stream music. However, I will say my FM transmitter still sounds amazing on the Lexicon sound system.
  • My Drivers door sill does not light up with the "Genesis" badge even though all the other ones light up blue. Simple fix?
  • How do I go about updating the DIS and the navigation maps?
  • My center dial "select" button seems to work and not work randomly. Any way to repair other than replacing the entire control unit?
  • As far as increasing performance, what are the best ways to go about it? I have read using 91 octane fuel, Lucas oil stabilizer and gas stabilizer, and a K&N filter are good things to start with. Is it worth upgrading the exhaust with the Magnapacks?
  • Any way to improve the suspension as far as going over bumps on the highway?
I LOVE the car so far, and even though it has some shortcomings I simply adore the engine, appearance, and driving experience in general.
That's correct.
Probably light bulb.
I wouldn't bother because it can only be done at the dealership. You will have to buy 6 DVDs (I think) and dealer will have to spend half day upgrading maps. Google Maps or Waze are much better.
The only performance updates I did is K&N engine air filter, SprintBooster V2, and Michelin Pilot Sport 4S summer tires in summer.
That's correct.
Looks like the scuff plate doesn't have a bulb. I removed it and it's just one led light piece so I have to order a new scuff plate entirely
1 How do I go about updating the DIS and the navigation maps?
2 My center dial "select" button seems to work and not work randomly. Any way to repair other than replacing the entire control unit?
3 As far as increasing performance, what are the best ways to go about it? I have read using 91 octane fuel, Lucas oil stabilizer and gas stabilizer, and a K&N filter are good things to start with. Is it worth upgrading the exhaust with the Magnapacks?
4 Any way to improve the suspension as far as going over bumps on the highway?
1. Pay the dealer $400 or so and bring a full tank of gas. They will run the car for 4 hours while they do the update. Yes that's correct, the car will run for 4 hours and burn a half tank of gas or so.
2. No, not really. Some folks have tried electronics cleaner spray.
3. Other than using 93 octane gas, no. Everything else is a waste of money.
4. Yes, you can swap in 2012 suspension parts (springs, sway bars and shocks/struts).
Do you think the update is worth it? To be honest, I actually really like the built in navigation. I know waze and google are better, but my phone screen is tiny and I like having everything built in. Any other benefits to the map and firmware update?
What Gunkk said.
I am not a auto mechanic, but I think running car's engine idle for four hours is not a good thing.
I saw in some other thread about updating maps on 1st generation of Genesis that some dealers connected battery to charger instead of running car idle for 4 hours.
No and no. I use Waze. But you do you.
