carguy75
- Jun 23, 2018
- Location
- Atlanta, Georgia
- Genesis Model Year
- 2015
Today I swapped my old OEM paper air filters for K&N air filters. I usually do not expect much performance gains from drop-in performance filters( about 5-8 hp gain). However, the K&N filters have a larger filter surface area (about 2in taller) than the stock air filters. The stock filters also look very restrictive since it is (1) paper(flow less by design) and (2) have a foam pre-filter on top of the paper.
I am sure that the stock filters clean the air better than the K&N filters, but I like a stronger running engine.
I will test how the engine feel over the next few hundred miles and then comment if I can feel a difference by switching filters. Some engine computers respond well to performance filters and some do not, time will tell if the 5.0 engine does or not. However, with the K&N filters I do have some high expectations for some decent power gains due to the increase filter surface size over the stock filters in addition to being high flow cotton.
The engine is rated to make 420 hp flywheel with stock filters, therefore I am speculating about a 15-20hp/10-15 ft/lb torque gain from swapping filters due to the large increase in filter size. So I am guessing about 435-440hp and 393-398 ft/lb flywheel with the K&N filters.
I forgot to add, the 5.0 V8 do not have a hot wire MAF sensor( uses a MAP sensor) for the oil in the K&N filter to mess up.
K&N filters compared to the stock filters.
Stock filters with the foam pre-filter layer.
K&N fitment is good.
K&N logo on air box, job done.
