led bulbs
imitiday
western pa.
are 31 mm festoon bulbs # 6418 correct size? If so,is there any trick to install? where to buy?
What application would you be talking about?? Possibly license plate??
my bad!! i am thinking trunk & plate,rear only.any trick to getting these
bulbs out? tks.
bulbs out? tks.
Festoon Dome LED Light Bulbs (Note: Always measure your festoon bulbs from tip to tip)
31mm = 1-1/4"
36mm = 1-3/8"
39mm = 1-1/2"
44mm = 1-3/4"
When two or more lamps are listed for the same application, remove the lamp and check the numerical designation.
2009 HYUNDAI Genesis (With HID (high intensity discharge) headlamps)
Low beam headlamp
HID-D1S
High beam headlamp
H7
Parking light
2357A
Front turn signal
2357A
Rear turn signal
1156A
Tail light
LED
Stop light
LED
High mount stop light
LED
Fog/Driving light
H11B
License plate
6418
Back up light
921
Front sidemarker
168
Dome light
DE3022
Trunk/Cargo area
6418
- Osram Sylvania -
