LED headlight strips as DRL
I don’t have electrician background but I would first make sure all ground wires are grounded properly and then check the capacitor. Maybe try replacing it.
Warning. Do this at your own risk. I accept no responsibility if you damage your vehicle.
This is just a reference that I did to my vehicle.
This mod will light up the LED strips as DRL while your switch is on auto. The amber lights will be off When the parking lights or headlights come on the led strip dims , when the blinker is on the amber light will flash and so will the led strip. ( at a later date I will add info on how to have the led light go out while the blinker is on.
Tools and supplies
panel tool
8mm 10mm 12 mm sockets and ratchet with extension
Phillips head screw driver
razor blade
wire 3 colors
wire ties
wire strippers and cutters
4 sets of waterproof wire connectors (something that can be disconnected and re connected)
tube of silicon
in line fuse holder and 10 amp fuse
2 SPDT relays and harness or female blade connectors 20 amp minimum ( auto parts store or ebay)
3M super 33+ electrical tape (Home Depot)
drill with bit about the size of 22 guage wire
recommended : solder and soldering iron.
I think thats it
you will need to remove the headlights and to do that you need to remove the front bumper cover
it actually comes off fairly easy.
Remove the headlights and on the bottom there is a round access panel. Turn it and remove. This will give access to the wires on the LED board. There is a harness with 3 locations and only 2 wires.
Your going to add a wire to the blank spot. I do not have access to the factory harness pins on this harness or the headlight connector so here is what to do. Drill a small hone next to the factory headlight connector just big enough to insert a wire about 22 guage. Run the wire in the light assembly and tin the end (strip the wire and coat with solder) this will give it rigidity. Unplug the 2 pos harness and insert the new wire.
Tape it and wire tie it to the other 2 wires so it doesn't pull out and re connect the wire.
On the end outside the light assembly connect half of one of the waterproof wire connectors.and then add a wire tie to the wire on the inside of the assembly to keep it from pulling out. silicon the hole you drilled to seal it. set lights aside to let the silicon dry
now inside the car you will need to remove the lower dash panel covering the wires at the fuse box you will need to run wires 3 of them from the fuse box to under the hood near the brake fluid fill. near the firewall on the drivers side.
At the fuse box you will see this harness
on the 4 pin harness the thick wires. The wire on the left (red) is BATT. Connect the in line fuse leave the fuse out for now. Connect a length of wire to the other end of the in line fuse holder.
The other 2 wires are for the left and right blinker. The one on the left is for the right blinker and the one to the right is the left blinker.
Do not use scotch lock type of wire taps. They will fail and look awful. Use wire strippers and make a cut in the insulation in 2 spots about a ¼ inch apart and using a razor blade slice between the cuts and remove the section of insulation exposing a section of bare copper. Wrap your stripped new wire around and solder and tape. If no solder just wrap tight and tape.
There is a grommet in the firewall to the left of the brake pedal. You will need to run the wires to this grommet. Using a razor blade cut a slit in the grommet at the indentation near the top. You will need to slide a snake through the grommet. A long wire tie 3ft or so (Home depot) with the end cut off works well. Keep moving is and out until you can get to the other end under the hood. Its tight in there so it may take some time. Tape the wires to the snake, put a drop of dish detergent or soap on the wire where its tapped and it will slide right through.
These will now wire to the relays. The reason for the relays is the blinker lights were wiring into are for the rear and we want to isolate them and it will also prevent any more current on the circuits. I made a little bracket to mount the relays but you can just wire tie them to a harness
On the bottom of the relays there are 5 tabs with numbers next to them
label the relays left and right
wire both tabs 85 to ground
wire both tabs 87 to the BATT wire you ran
tab 87a is not used
tab 86 on left relay goes to the left blinker wire you ran
tab 86 on right relay goes to the right blinker wire you ran
tab 30 on left relay goes to the left headlight
tab 30 on the right relay goes to the right headlight.
Run 2 wires from tabs 30 to the left headlight and continue the right side wire across the front of the car following existing harnesses to the right headlight.. these wires should be covered in loom and can be run under the beauty cover near the left fender. Wire tied to the hood pop cable.
now install the headlights
At the headlights you need to find pin 10 and cut it
On the side of the wire toward the car connect the other half of the waterproof connector you wired to the headlight and connect them together. Install another waterproof connector on the light side of the wire you cut and to the blinker wire you ran and connect them. Do this for both headlights.
Put the fuse in the fuse holder and test, be sure its bright enough for the DRL to be on .
And test, if they're not working check all your connections. You will hear the relays clicking when the blinkers are on. This is normal.
Tape up the wiring at the relays and loom or tape all exposed wiring and secure with wire ties
if for some reason you want to put it back to the way it was just reconnect the wires on pin 10 with the waterproof connectors you installed and pull the fuse out.
reassemble your car
this is the first write up Ive ever done so I hope I didn't miss anything
let me know if you have questions
About how long does this entire process take? TYIA
It took a couple of hours. I also spent a good amount of time familiarizing myself with every step I need to take before touching anything.
I took the full write up and gave it to my local audio shop who has done some custom things for me in the past. They say 5-6 hours. It seemed a little excessive, but I was not sure.
Also, what turn signals did you end up going with? Stock incandescent? Or LED?
I think I spent even more time than they quoted you for so their quote is fair. They might be able to tackle it quicker than that, given they are specialized shop and have the right tools and have the experience. I had none
You still got it done cleanly. I am considering doing it myself, but I would probably have to take time examining before I dove in.
Good luck and let us know if you hit any road blocks. We'll be happy to help.
Silly question. Could I, in theory, put a jumper wire from the turn signal to the LED strip so both are on during DRL and both blink when I am turning? I am going to switch the turn signals to switchback LEDs so I do not mind if they stay on. (Assuming switchback LEDs work)
I would not put a jumper wire directly from the turn signal to the DRL. I would use the 5 pin relay and supply the power from the fuse box. I would still not do it that way though. Your white strip will blink with the blinker at night and I don't think it will look right. But again, this is your car so you decide. It will definitely be a quicker project and you will not have to worry about using resistors etc.
Here is what it would look like if you were going to keep the blinkers and bright DRL on at the same time.
and here is the proper way:
The choice is yours :-)
I had a random thought and I have no idea if this would work, would anything change if I bought a 17-20 G80 headlight?
(With 3 kids under 3 years old, every time I think I have time to do this, I don't. lol. Thats why Im looking for a shortcut if it exists)
You would still have to do the wiring because your current setup does not supply power to bright DRL. You would have to do the same thing.
Well frustratingly the shop said, "we did our own research and people have been complaining that the "LED flash intermittently" and "turn signals do not work" and 2 other bs excuses. I think they are afraid of taking responsibility for the job. Oh well. =( I guess I will need to figure it out
I think their feedback is on the switchback turn signal bulbs as people complained about the LED turn signals a lot in the past. I switched to LED with no problems. There were never any problems with DRL flashing so I don't know what are they talking about. I would definitely not have these guys touch my car if they specialize in this plus they are giving all the diagrams and instructions.... Try another shop. It will not hurt.
