jetrep
- Jan 27, 2021
- Location
- Southern NV
- Genesis Model Year
- 2019
- Genesis G70
Yesterday I lifted my G70 using the Quickjack so I thought I'd share my experience for others.
I have a Quickjack BL-5000SLX. This model is too short for the G70. The lifting points on the G70 are spread very far apart. I had to buy the Extenders for $239. Even the extenders (steel weldments that simply drop on top of the lift, adding 5-6" of length) don't quite reach the center of the lift points. I still made it work by using the standard blocks that came with my lift. I used the shorter ones but the taller blocks would also fit.
It's also worth mentioning I purchased the overpriced square pinch weld rubber blocks from Quickjack. These are not usable as they're too big to fit the relatively small openings that Genesis provided. The other blocks they sell that have the rounded top portions will likely fit in the openings in the car but they won't work with the adapters (or the BL-5000EXT which is essentially what the extenders turn the SLX into). The rubber blocks I'm using are not perfectly centered on the lifting points but it's working fine and I'm not worried about any problems developing.
If you're looking for the ideal Quickjack for the G70 I'd probably go with the BL-6000XLT. The downside of course to these longer models is they won't fit between the wheels of shorter wheelbase cars. The EXT and XLT stand zero chance of working for my S2000. I've also read they're soon releasing models that offer higher lift heights so those might be worth looking into.
