richlang
- Mar 18, 2026
- Genesis G70
Can someone recommend a brand of non-dusting, performance, front brake pads for a 2025 G70?
Explore Pet Insurance!
The Food Order Method
Just a quick note to let you know that this topic has been moved out of the G70 Lighting forum and into the G70 Brakes forum.Can someone recommend a brand of non-dusting, performance, front brake pads for a 2025 G70?
Non - dusting and performance is an oxymoron.Can someone recommend a brand of non-dusting, performance, front brake pads for a 2025 G70?
For non-dusting, you may be able to switch to drum brakes. You may have to make an adapter.Can someone recommend a brand of non-dusting, performance, front brake pads for a 2025 G70?
Funny boy! As a matter of fact though, semi-metallic pads dust much less.For non-dusting, you may be able to switch to drum brakes. You may have to make an adapter.
On the contrary, I Performance brake pads usually have higher metal content which dusts less than a soft composition of street and regular driving pads do. High performance pads can be harder on rotors since there's more metal and metal than a softer pad composition but the softer pad emanates more dusting.Non - dusting and performance is an oxymoron.
No they don't. The pad compounds themselves might not wear as fast, but they wear on rotors much more aggressively than organic and ceramic compounds, so the end results are more overall dust generated with metallics.Funny boy! As a matter of fact though, semi-metallic pads dust much less.
I believe the OP used the term "non-dusting", not lower dust. Good luck with that.On the contrary, I Performance brake pads usually have higher metal content which dusts less than a soft composition of street and regular driving pads do. High performance pads can be harder on rotors since there's more metal and metal than a softer pad composition but the softer pad emanates more dusting.
Yes, I should have said lower dusting.I believe the OP used the term "non-dusting", not lower dust.
So do you think most owners just stay with factory pads or try to upgrade to pads like Bosch? I read an article that X Wagner, PowerStop, EBC, R1, and Raybestos were NOT considered very good whereas Zimmerman, Centric, ATE Ceramic, and Bosch Blue of QuietCast were good.No they don't. The pad compounds themselves might not wear as fast, but they wear on rotors much more aggressively than organic and ceramic compounds, so the end results are more overall dust generated with metallics.
The dust that they generate are also more corrosive and so need to be cleaned off alloy wheels more frequently, lest you wish to have the dust etch into painted wheel finish. I know, cus semi-metallics used to be the only option for HPDE applications , so we had no other choice in the old days.
Some metallic compounds, like copper, are also potentially toxic to the environment, which is why they are being banned in more and more countries. These days, there are better options.
Nah, last time my brakes were getting down I just bought a new car. Problem solved.So do you think most owners just stay with factory pads or try to upgrade to pads like Bosch? I read an article that X Wagner, PowerStop, EBC, R1, and Raybestos were NOT considered very good whereas Zimmerman, Centric, ATE Ceramic, and Bosch Blue of QuietCast were good.
Article by whom and where please?So do you think most owners just stay with factory pads or try to upgrade to pads like Bosch? I read an article that X Wagner, PowerStop, EBC, R1, and Raybestos were NOT considered very good whereas Zimmerman, Centric, ATE Ceramic, and Bosch Blue of QuietCast were good.
Any article that lump those brands wholesale together like that are not worth reading.So do you think most owners just stay with factory pads or try to upgrade to pads like Bosch? I read an article that X Wagner, PowerStop, EBC, R1, and Raybestos were NOT considered very good whereas Zimmerman, Centric, ATE Ceramic, and Bosch Blue of QuietCast were good.
I would not be able to find it. It was on YouTube,Article by whom and where please?
I've used various types of EBC compounds for years on various cars and motorcycles with excellent results.
Probably been pulledI would not be able to find it. It was on YouTube,
Same group recently reviewed car batteries so the brakes youtube should still be available.Probably been pulled![]()
