Loss of SCC operation post battery change
Jasmeet16
Hi, I changed the car battery as the one in the car was not the right one for the vehicle.
I reset the power windows and sunroof as per the manual.
However, now my cruise control/SCC system won't work. I am unable to set a speed.
I have checked the brake switch and SCC fuses and no issues. The brake lights work as normal so assuming the brake switch is ok.
Final thoughts are around the throttle body, does it have a relearn procedure that I need to complete? I have no issues with throttle response though
I have used a generic code reader and nothing was found.
Hope you can help offer guidance.
Car is a UK spec 3.8 RWD 2015
Need to take to shop to read SCC codes or pull battery cable again.
