Lost passenger side seat slide control switch knob
RyanB
Elmhurst, IL
As the title states somehow the passenger side seat adjustment switch to move the seat forward and back came off and got lost. I found replacement switch knobs for the prior genn but for the 2015 on all I can find is the full control panel for $$$$. Called my dealer and they can't find anything other than ordering the entire assembly. I can't believe that you can't replace just the plastic knob. Has anyone else had this issue and if so were you able to locate the knob without replacing the assembly as well? Or does anyone own 2014 and if so are the switches the same shape as the 2015 and current?
88987-3M400-BR - Genuine Hyundai KNOB-FRONT SEAT SLIDE,RH
this is the part for the 2014 model
I don't have an answer but I know what I'd do. For 2.47 I'd buy it and figure out what I have to drill, cut, or glue to make it work.
Agree is makes no sense to replace the entire panel.
The knob for 2015 Genesis is not sold separately. 2014 Genesis has two switches for sliding and reclining respectively but these switches are merged into one switch assembly since 2015. You can buy used one on ebay for under $90. Still pricey but no other option available.
I am following this thread as well. I recently purchased a 2016 Genesis and somehow lost the forward slide button switch. If I am hearing correctly, you have to purchase a whole assembly? You cannot just buy a replacement button switch?
