Love the Car… But!!
Robsmith
2011 4.6 Sedan, Can someone tell why I’m only getting 12,000 miles out of 70,000 tread life tier.. The 2nd set has 5,500 miles an the back is half gone!! It’s my wife’s car.. normal driving! An it’s been in shop 2 times for Tier alignment and checks out all good.. Thanks..
Do you have a teenage son that borrows the car?
I would understand if He was Driving lol just the wife drives if..
Who checks the air regularly in your wife’s “tiers?”
I do all Maintenance, I keep them at 33 psi check every 8 days… Any advice would be greatly appreciate.. it’s super Nice Car I’m to the point of replacing the everything in the Rear!!
Well, the early ‘09 to ‘11 sedans did have rear suspension problems which were improved for the ‘12 year.
What would be good upgrade? Thanks
What is the wear pattern - is it even from inside to outside across the tread? Or is the inside or outside shoulder wearing faster? If either shoulder is wearing faster, the camber (how the wheel leans in or out when viewed from behind the car) is incorrect.
If you run your hand along the tread front-to-back and then back-to-front, does it feel the same? (like petting a cat) If it feels smooth one way but jagged - like you are raking your had across a file or saw blade - then the suspension has a toe alignment issue.
If both shoulders are wearing fast, but the center region has significantly less wear, that indicates under-inflation. Verify your gauge is correct. Wear in the center of the tread but not on the shoulders indicates over-inflation: the tire is bulging out like a basketball.
A patchy wear pattern - as if somebody is randomly slicing off tread chunks - indicates a suspension that is oscillating vertically due to worn shocks or horrible bushings.
Vehicles with a true limited slip differential that is overly-tight basically act like a solid axle: when the car is going around corners, the outside wheel needs to rotate a little faster than the inside wheel; differentials allow this. Limited slip differentials allow it too but limit the RPM difference between the wheels. That way, if one wheel is on ice and the other on pavement, when the wheel on ice starts slipping like crazy the differential will tighten up and send power to the wheel with more traction. Regular differentials (called "open differentials") will end up sending all engine power to the uselessly spinning wheel. Genesis cars, with the traction control system, sense this and apply brakes to that spinning wheel to force engine power to the other wheel, electronically emulating a limited slip differential. Anyway, if a limited slip differential is too tight, acting locked up 100% of the time, the wheels cannot turn at different RPMs going around corners which creates all sorts of wear. Test: with the car on jackstands, transmission in neutral, parking brake released, try to turn one rear wheel. The other wheel should turn too. Now have a helper hold one wheel still while turning the other. If you can't turn them independently the differential should be checked by a pro.
Also: when doing an alignment, many shops jack the vehicle up and then lower it onto the alignment machine. That lets worn suspension parts and bushings relax... so when the tech checks the suspension readout things look okay. But get driving on the road, with loads applied to the tire contact patches, those worn suspension pieces shift/move out of proper position. Driving the car straight onto the suspension machine, without jacking it at all, works better.
mike c.
Yeah man thanks for info.. the tires are wearing out across the tire, but more so on the inside of both. Thanks again…. i’m a good parts changer. That’s as far as my abilities go.
