F1-fan
- Jun 25, 2020
- Genesis G70
Is this the standard view for SXM radio with the new update?All of the above.
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
What USB? You have a G70 don't you - need an SD card?...usb availability to mail to customer will be between 23-26 April. I asked if SD card stays in dash and he did not know....
SD card remains in the car...the car constantly pulls data from it. If you get a new SD card preloaded...simply swap.Chat with Mapnsoft (Oliver) and usb availability to mail to customer will be between 23-26 April. I asked if SD card stays in dash and he did not know. I assume it stays.
I will use the mailed usb as I want to limit the sources of contamination on this update
Unless you don't use the built in Maps. I leave the SD card out and use Google maps. The car's Infotainment loads faster that way too.SD card remains in the car...the car constantly pulls data from it. If you get a new SD card preloaded...simply swap.
I'm not familiar with the display on a G70 - on boot up what shows on the map section without an SD card?don't use the built in Maps
Vehicles | Navigation system | Model name |
2019-21 G70 | Standard Gen5 | IKAS.S5AMC.CA |
2019 G80 (8 in. Touch) | Standard Gen5 | DHAS.S5AMC.CA |
I hope this addresses the issue around not being able to save SiriusXM channels as favorites when hitting the "star" button. Each time I try, the system reverts back to the Home Screen then back to Radio without the channel being saved. Seems some folks have the issue and others don't.G70s updates temporarily unavailable
Reason / Period / Vehicles
1) Reason : Software inspection of Sirius XM function
2) Period : April 20, 2021 ~ April 27, 2021
3) Vehicles
Vehicles Navigation system Model name 2019-21 G70 Standard Gen5 IKAS.S5AMC.CA 2019 G80 (8 in. Touch) Standard Gen5 DHAS.S5AMC.CA
3) Vehicles
I agree. It's much more pleasing to the eye and the sound is great.I just installed this update, having downloaded earlier in the week. (2019 G70)
To me, the screen now looks much more modern, i'm a fan of the update. Haven't used satellite radio so cannot comment there.
The biggest plus is that there is a noticeable increase in sound quality. They have changed something here for the better, significantly IMO. This is judging FM radio before/after which I listen to daily. Have not tried other sources but would expect the same results. Very happy.
I think I have this problem too. Before I used to be able to press and hold the preset button and it would save it. Does this version use the same process or is it done differently?I hope this addresses the issue around not being able to save SiriusXM channels as favorites when hitting the "star" button. Each time I try, the system reverts back to the Home Screen then back to Radio without the channel being saved. Seems some folks have the issue and others don't.
It no longer works that way (the way it should). Now you have to select save as preset (or something like that) from the menu.I think I have this problem too. Before I used to be able to press and hold the preset button and it would save it. Does this version use the same process or is it done differently?
I don't know about the Sirius stations but for AM/FM stations you press the empty star below the frequency dial on the screen.I think I have this problem too. Before I used to be able to press and hold the preset button and it would save it. Does this version use the same process or is it done differently?
The re-released version now allows me to save SiriusXM channels as favorites, though it still organizes in numerical order rather than the order I want.I hope this addresses the issue around not being able to save SiriusXM channels as favorites when hitting the "star" button. Each time I try, the system reverts back to the Home Screen then back to Radio without the channel being saved. Seems some folks have the issue and others don't.
