Metallic trim around door
JBCM
Genesis G80 Sport
Well I assume hope that the metal trim around the doors is stainless steel and has discolored so what have you found best to clean and restore?
There are several threads in this forum discussing this.
My 2018 G80 Sport has had the window trim replaced multiple times due to this discoloration. I'm out of 5 year/50K mile warranty (at ~56K miles) and my window trim is again noticeably discolored. 8( The discoloration cannot be removed. The issue is the "bronze" coating/lacquer has worn away. (specific to G80 sport and possibly G80 5.0) Over the past few weeks I buffed out all coating/lacquer to make the trim consistent. I tested this on an old/replaced piece of trim. Determined aluminum wheel cleaner and a microfiber cloth by hand was the best option. Using a buffer/Dremel causing imperfections. I masked off around the trim. This was a tedious/time consuming process. I guestimate I spent 5 hours over the past 3 weekends.
