Bryandowen
- Dec 28, 2016
- Location
- Northern California
- Genesis Model Year
- 2015
I started my 2015 Genesis (5.0, Ultimate package, ~104k miles) today, and I noticed all sorts of weirdness out of the blue:
- Check ECS
- Check LKAS
- Check BSD
- Check PSB
- Check AEB
- Check TPMS
- Blinkers and hazards don't work
- Speedometer, tachometer dials don't work
- Shift indicator is blank (there's a box displayed, but nothing inside of it; shifting into Drive yields nothing)
- Power steering is harder than normal (but not completely dead)
- Radio works, but gives "Battery discharging" warning as if the car is not running
- In reverse, I see the indicator showing where the car is headed, but no camera image
I'd seen something like this happen before, and turning the car off and back on fixed it. This time, no dice. I took the car for a short drive then parked and turned it off and back on, and still no dice.
The only possible clue I can fathom to any of this is that a few weeks back I hit a pothole driving through Vail, Colorado, and my Check AEB indicator came on and has stayed on since. That I assume is due to some misalignment or loose connector or even damage to the AEB sensor, but I can't imagine that would somehow become aggravated over time to cause all these other issues. Maybe I need a more active imagination. With everything electronic, nothing should surprise me I guess.
I saw talk about an inoperative brake switch causing similar issues, but I've verified that the switch works and my brake lights come on. I also checked the "3 MODULE" fuse under the hood and it's fine. I'll start checking other fuses, but would be tickled if someone saved me a goose chase because they have a good idea what to look.
Thanks y'all.
-Bryan
- Check ECS
- Check LKAS
- Check BSD
- Check PSB
- Check AEB
- Check TPMS
Thanks y'all.
-Bryan
