My car wouldn’t turn off
Kimmie
My car engine would not turn off for 7 hours it continuously ran, I’m wondering has anyone else experienced this issue and these door handles come right off in your hand I’ve had to have two outside door handles replaced and I’ve had 2 undershields replaced at $1100 a piece, I’m not happy with the quality of this vehicle
So, you pressed the start/stop button and nothing happened?
Did you also try pressing and holding the button for several seconds?
Does it/has it ever not responded to the button press when you were trying to start it?
Did it run out of gasoline to stop, or did you find another way to stop it?
How would you stop an engine today? Stuff the air intake? Years ago I'd have just pulled the wire from coil to distributor.
I did hear of another case (not a Genesis) and he drove to the dealer.
One thought would be to pull the fuel pump fuse, but I don't know if the HPFP on the engine would still be able to suck the fuel out of the tank or not.
Pulling the ignition fuse should be a certainty, but maybe could cause a ring to get washed down?
It would probably be best to find the fuse for the fuel injectors. If you can't find it, blocking the air intake as you suggest might be the safest option.
