Navigation system updates for 2015 Genesis
bgillson
Is there a process by which an owner can update the navigation system on the 2015 Genesis? My dealer advised this has to be done by the owner, they do not do it
Depending on the Genesis trim . I think the non-ultimate ones can be upgraded for free using software download.
For the ultimate its a $175 charge for the drive
Hmmm. Why would the ultimate map update cost $ for the same update as the base?
Because it’s the same data that is being updated. Map and poi data. Do you honestly believe they create different updates for different cars
it’s the same update for all models in the same year be a Hyundai or Genesis, a Sonata or a Santa Fe
My question should have been why does the ultimate update cost $175 and the base update is free, for essentially the same map update? I'm wondering if I should even bother to update my 2015 ultimate maps.
No idea why the cost difference.
Should you update? Depends. The POIs will change as the Best Western in Podunk is now a Marriott or the supermarket closed. If you use them a lot and find many errors, perhaps you should update.
If you want to go from Boston to San Diego, chances are, the highways have not moved and you can still get there. I80 is in the same place it was on your last map update. So is I70, I40, etc. If you still get where you need to go, save the money. Only you can evaluate the real need.
Does the Ultimate update include the ability to read text messages?
It does on the 2018 but I have no ideal if it does on other years.
The base is not free, it is listed as UNAVAILABLE. This has been discussed. Hyundai has stated the 8” unit programming had a bug and they are working it out so it is delayed and unavailable.
