New Engine Noise
spark763
2013 sedan with 3.8. 23000 miles, when accelerating I hear what sounds like an exhaust leak or air leak. Anyone have an idea what could be causing this. I checked everything and everything is tight. Going to dealer next week to have it checked.
Thanks
My guess:
A loud hiss on acceleration (absent engine performance issues ala vacuum leak) is probably a gasket failure or hole somewhere in the exhaust.
If you want to sleuth it out, get a vacuum cleaner hose. Hold one end to your ear and use the other end to probe around the engine/exhaust for your hiss.
Did you ever find out what was causing the noise?
I have a 2012 4.6 and have a loud hiss noise under load like a exhaust cover is missing.
Been in once, they think its the timing belt, needs adjusting. Going in next week to take the engine down further. Will update...
Timing belt?
You mean timing chain?
I can't imagine a timing chain making a hissing sound unless perhaps it is the sound of a idler bearing going bad.
