New Releases
GSC Power-Division has released a Stage 1 and Stage 2 Camshaft set for the Hyundai Genesis Coupe 2.0L Turbo.
Stage 1​
The GSC Power-Division S1 cams for the Hyundai Genesis Coupe are designed for those with the stock turbo up to the 550hp range These cams will not sacrifice any bottom end loss over stock cams; nothing but gains and will promote faster spooling of the upgraded turbos. Gains of 20-50whp (depending on Turbo) have been seen by simply bolting the S1 cams in. Designed for a rev range of 3000-7500rpms, these cams work well on the stock valve springs.
• Designed for a rev range of 3000-7500rpms
• the S1 cams work well on the stock valve springs.
• Intake 264 / 220 @ .040" / Peak Lift 10.2mm
• Exhaust 264 / 216 @ .040" / Peak Lift 10.0mm
  • Part #: 6060S1
Stage 2​
The GSC Power-Division S2 cams for the Hyundai Genesis Coupe are designed for those with 600HP+ in mind. Gains of 20-60whp (depending on Turbo).
• Designed for a rev range of 3500-8000rpms
• The S2 cams require an upgraded valve spring.
• Intake 272 / 226 @ .040" / Peak Lift 10.4mm
• Exhaust 270 / 222 @ .040" / Peak Lift 10.2mm
  • Part #: 6060S2
Turbo XS releases a new Genesis Coupe 2.0T stealth-back downpipe system. This downpipe features a full 3 in piping, in a 2 part system, that includes the downpipe and the 02 housing, to help eliminate check engine lights. This is none of the best downpipe kits that we have seen on the market, so far, for the Genesis Coupe 2.0T. This Turbo XS stealthback downpipe performs amazingly well, producing +13.9 ft/lbs of torque and 13 whp, by just bolting it on!! And even better is that when this stealthback downpipe is combined with their reflash you can see gains of 60 ft/lbs of torque and 42 whp over stock!!! Now that is amazing for just a downpipe!! So put your order in today, so that you can reserve yours and be the first to own this amazing downpipe.
AMS Performance has released an upgraded short block for the Hyundai Genesis Coupe 2.0T.
Features:
Includes
* Manley Turbo Tuff I beam connecting rods
* Manley 2.0T THETA pistons with rings
* New OEM Main, rod and thrust bearings
* Precision AMS spec machine work on block & crank
* Precise, documented hand assembly
Options
* ARP upgraded head studs
* Engine gasket set
* New OEM oil pump
* Timing Kit (New OEM timing chain, 2 tensioners and guide)
* New OEM water pump
Specifications
* Displacement: 2.0 liters
* Compression Ratio: 9:3:1
For More Info Visit:
http://www.ecgtuning.com/AMS-Hyundai-Genesis-20T-Stage-1-Shortblock-AMS-GEN-SB.htm
