No Sound from Rear Speakers
tombea
I've had my Genesis for about three months and I have never had any problems with the sound. I read stories here about how great the Lexicon system was and I turned up the volume several times and it was nothing to write home about. I found out why when we took a trip with another couple who sat in the back seat. There was no sound coming from the three speakers on the package shelf.
Is there a separate electrical circuit for this that might have a blown fuse or should I head for the dealer?
Thanks,
Tom
Thanks,
Tom
Is it safe to assume you have checked the speaker balance? Meaning, you have gone into the system settings and have made sure the output is to all of the speakers?
I did that, the little dot is smack dab in the middle of the screen:)
Hmm, that's weird. I don't think there's a separate breaker or fuse for the rear speakers only. I'm guessing it's a defective amplifier.
Definitely go to a dealer.
Dan
Set the dots for the rear speakers only. See if you hear anything. Then set the dots for just the left rear. Then the right rear.
Thats how I tested mine. At first I did not think they functioned, but doing that test, I found that they did work after all.
Yeah if it's not set wrong with the fader then the rear amp is the most likely culprit. Could be a bad remote wire, fuse, amp, etc. Contact your dealer.
