19 G70 3.3T
- May 24, 2024
- Location
- Texas, USA
- Genesis Model Year
- 2019
- Genesis G70
The car lovers social network
Automotive components
Create videos that captivate
Automotive Hot or Not
Vehicle hacker protection
Genesis parts & accessories
Advertise with us!
Advertise with us!
Exactly. That's what the exterior lock/unlock button is for. Works exactly as it should.My only question to you is this: Why are you still using the interior door lock switch to lock the car? Just close the door and push the button on the exterior door handle. That immediately locks all four doors leaving the car both closed and secured. The factory programming is there to insure there is no possible way to lock your keys in the car (or the trunk for that matter) unless, like you've said, you do it absolutely on purpose. I cannot tell you the last time I took my key fob out of my pocket in order to operate the car in any way.
Although I did read the entire owner's manual I apparently did not retain this tidbit. But I tried it today and yes, it does work.My only question to you is this: Why are you still using the interior door lock switch to lock the car? Just close the door and push the button on the exterior door handle. That immediately locks all four doors leaving the car both closed and secured. The factory programming is there to insure there is no possible way to lock your keys in the car (or the trunk for that matter) unless, like you've said, you do it absolutely on purpose. I cannot tell you the last time I took my key fob out of my pocket in order to operate the car in any way.
On my 24 the rear quarter view in the tach can be turned off, which mine is.Ok, I have had my 2025 G70 3.3T. for 2 months now. I am just getting out of the break-in period. (Previously a 2020 G80 3.3T Sport)
- True stick shift. The new G80 dial is a steaming piece of crap.
- Real gauges, with moving indicators that are mechanical in nature. Big +
- Sport package with a true LSD. Nirvana. Last 4 cars had brake modulated rear wheel traction control. I almost bought a Lexus IS350 for that reason alone.
- Very spirited engine. The throttle curve makes it seem very eager to move.
- The Sport+ mode. When the seatback grabs you, you know good things are going to happen and they do.
- The driver door is correctly sized. What? OK, when you are an aging Boomer like me with recent knee replacements, I can fit in the door. My wifes Mazda CX-50 is problematic.
- The front seats are very comfortable. Excellent adjustability.
- The choice of tires is commendable. I cannot seem to break them loose no motter how hard I try. The Michelin Sport are a FAR CRY better than the absolute crap Continental tires on my G80 Sport. I had to replace multiple Continental tires on my G80 from blowouts, for less than blowout causes. At my cost.
- The multipurpose display was adequtely sized and properly positioned. I hate an iPad for a dash.
- Lots of real controls and switches that really do things that you need.
- Although I was against having the HVAC controls linked to an LCD touch screen, it has proven itself effective with enough manual controls.
- Having a USB A style plug is acceptable for intefacing with IOS Auto, since it is the most standardized connector in history, There are also USB-C connections avalable for charging.
- It should always be a RWD with LSD car the way that god intended. If you prefer the AWD, thats on you. More parts to go wrong.
Dislikes:
- The entertainment system is dated, even by Boomer standards. The controls are opposite on the wheel from my G80 which is peculiar.
- This is not a G70 specific issue, but I have never seen a wireless phone charger that actually works with a phone case on it.
- The rear seat has insufficient room to seat a human when I am driving. This is common for what I consider a BMW 3 series car size. To be fair I never used the carrying capacity of my G80. I see it now as wasted space 97% of the time. A Sunroof delete option would improve the seating situation.
- The dual function Tach/Turning turn signal enabled rear quarter view is not intuitive. There are other audible/tactile indicators that are more useful already in the car. A functional mechanical tach would be better appreciated. The disappearing tach redline in normal driving mode is problematic.
- The Sunroof? I don;t know because it has never been opened, very much the same way my G80's was never opened. An extra expense without purpose.
- The wheels/rims on the 2020 G80 Sport, in the black pattern were perfect by every standard. Really stunning. The new G70 should have just used them. New does not equate to better.
Summation:
If you built the G70 just like mine for eternity, I would buy it over and over again. That is how much you got correct on this fine car. Add the 2020 G80 wheels, and ditch the combo tach for a real one. One thing that manufacturers have missed and it is not just Genesis, the BMW is an abortion... Please in future models PLEASE make the gauges increase clockwise. My spedometer does but the tach is a mirror of what would be correct. A 100 years of cars using that method leaves a lasting impression.
My history: Two of my very close friends purchased cars with digital dashes. A BMW M550 had to replace the dash due to total failure at 5,400 miles at a cost of $5900.00 (under warranty). My second friend had a beautiful Cadillac SUV with an all digital dash. It failed completely on a 1500 mile trip to Florida. No speed, no gas level, no nothing for 1,000 miles. It was replaced by Cadillac three times, and ultimately lemon lawed a refund. Digital dashes are new and unnecessary for proper vehicle function. I have never seem an LCD screen last for more than a few years. The Texas heat is not merciful on electronics and never will be. Sometimes an analog hybrid is a better choice.
